C550i with even magenta lines only on copies
  • mrwho
    Major Asshole!
    • 4299
    [CQ] C550i with even magenta lines only on copies
    Good morning all.
    A colleague went to a new customer to check on a C550i with fine even magenta lines on copies only. Scans and prints come out fine.
    Customer tells the machine always did that.
    My money is on the set up procedure not being made correctly (although in my time working with Konica Minolta it was a thick black border and not colored lines).
    Can someone confirm my suspicion? And, if not, what could it be then?
    Also, can someone share the PDF with the setup procedure for this series?
    Thanks.
    Mascan42
    Ibid
  • Brad6784
    • Mar 2015
    • 71
    Re: C550i with even magenta lines only on copies
    Originally posted by mrwho
    Good morning all.
    Thanks.
    Yep setup done done correctly, 100%
    • mrwho
      Major Asshole!
      • 4299
      Sorry, I don't quite understand - you're saying that this indeed caused by an incomplete instalation procedure?
      Do you have the installation guide perchance?
      Also, here's an example:
      My colleague also tells me he's not able to update the firmware - even after trying with two different usb thumb drives and reformatting them as FAT32. Could it be related?
      Mascan42
      Ibid
      • Brad6784
        • Mar 2015
        • 71
        [ATTACH=CONFIG]57522[/ATTACH]
        Sorry incorrectly, I replied in a rush!
        • KMFLT3CH
          • May 2017
          • 229
          Yes, redo the setup instructions.
          bizhubC650i_C550i_C450iInstallInstr.pdf
          • Oystercopy
            • Oct 2009
            • 623
            I'm with the others.. it sounds like it was not set up properly although I believe the date and time is all that really needs to be done.
            OC
            • fornerm
              • 82
              Lines of Shame, well, after more than 25 years in business it happened to me last week.....end of unnecessary comment
              • mojorolla
                The Wolf
                • 2599
                You beat me to it, redo the setup pertaining to date and time zones.
                As to the firmware, there is a specific procedure for formatting USB drives on these boxes:
                • tsbservice
                  Field tech
                  • 7986
                  We all know firmware it will work even without this procedure, it's matter of finding correct thumb drive that will play nicely with most machines.
                  • mrwho
                    Major Asshole!
                    • 4299
                    No problem. Thanks for your input.
                    [ATTACH]57531[/ATTACH]
                    Thank you very much. Already sent this to him.
                    Thanks. Relayed this info to him.
                    After 23 years doing this sh1t I still make n00b mistakes...
                    Thank you.
                    Mascan42
                    Ibid
