bizhub c 558 mix original scan problem
  • tonerspot
    • Nov 2008
    • 79
    Hi, i have trouble scanning mixed originals on bizhub c558 with dual scan feeder. Originals are only A4 and A3 size but some of A4 became A3 size when scan, need help.Tnx
  • emujo2
    • Mar 2017
    • 1579
    Re: bizhub c 558 mix original scan problem
    Your 1st step would be to grab the ADF test page that comes with every device and, after a good cleaning run it and all the associated setup steps. This will probably fix your issue.
    • REGSIS
      • May 2016
      • 435
      Just clean all ADF sensors. This applies to single TX feeders also, when mixed original option is used.
      • rrrohan
        • Sep 2011
        • 1977
        Did you run the mixed sized original calibration
        • REGSIS
          • May 2016
          • 435
          No. Just tests after cleaning and it lasts for a half a year then I clean again...... Customers set Mixed original for a defaulf option.
          • KM7155
            • Aug 2008
            • 146
            Hi, have u settled this issue?
            i have an c454e, original is A3 and A4, but the scanned job became all A3.
            • femaster
              • May 2011
              • 1512
              Since mixed original uses the paper path sensors to determine the paper size instead of the regular side guides and original tray sensors, either you have a dirty sensor, or a bad sensor in the paper path. I'm not familiar with European paper sizes, so I couldn't tell you which sensor it might be as I don't know the size relationship between A4 and A3.
              If I had to throw out my best guess, on that model the most likely culprit would be the sensor (or felt pad) just before the scan glass is dirty. That is hard to get to and collects dust the easiest.
                • 37529
                With a Ricoh there is a setting to tell it that you have mixed sized originals. Is that also true with KM?
                It could also have to do with the scanning software used.
