Thank you very much for the replys! I'll check the waste toner for developer and also try to manually fill with toner.
I'll get back when I've checked it out! Thanks again!
Thanks for all the replys, did check the waste toner bottle, but no iron. Did fill the IU with toner manually, and SHAKE it (foolish of me to not do that before, had forgotten to do so on this one), cleaned LED, lamp and TDS. Things went almost away directly but after running 2-3 A3 pages filled with cyan and with TCR level set to 3 the clouds went away!
The grey patterns are also very good now as they should be, so I would say this is solved now thanks to you! Thank you very much for your posts!
