Hi! I'm curious about the image quality on the Bizhub C450, when compared to the older CF3102 the C450 got this very coarse pattern when printing grey colours. I'm not sure if this is a feature or a setting, since all other colours are very even - it's just the grey! The pattern looks like a lot of small "boxes" in the grey areas, like a raster pattern. The other colours are more like dots as it should be when printing for example pictures.
See the attached pics for a enlarged scanned detail of the pattern appeared on grey fields. It maybe looks worse on the scanned pics but the pattern shows more clearly.
I've tried a lot of different driver settings and the pattern appears more or less but never gets as even as on the other KM machines I'm comparing with...
Could somebody just tell me if this is a feature of the machine or a setting/adj. issue before I try to correct it since I don't have any other C450 to compare with. The machine has about 266 k on counter and much life left on consumables. Thank you in advance!!
