C454e print problem
  • piksel1983
    • Oct 2018
    • 38
    Re: C454e print problem
    Originally posted by Mr Bo
    Hi piksel1983
    In SM there is a mention of high voltage unit, try replacing it
    I thought about it. Will try it on monday probably becouse im out od ideas.
    Wysłane z mojego Mi 9 SE przy użyciu Tapatalka
    • allan
      RTFM!!
      • 5459
      Check the sensor output for the loop sensor(s).
      Whatever
      • Mr Bo
        • Mar 2023
        • 28
        Hi piksel1983
        How's the situation of C454?
        • tsbservice
          Field tech
          • 7927
          #19
          Loop sensor may need to be changed.
          • piksel1983
            • Oct 2018
            • 38
            #20
            Hi guys, i have a few days off so machine is still on service. Haven't swapped hvpb yet. Will try that and check loop sensor
            Btw thanks for reply
