C454e print problem
  • piksel1983
    • Oct 2018
    • 38
    C454e print problem
    Hello everyone.
    Does anyone have a print problem like on test page? What can make those lines. The problem becomes before fuser unit.
    I've replaced:
    All drums
    ITB
    Fusing unit
    ITB motor
    Fusing motor
    All register tray with clutch
    Laser unit
    Transfer roller
    It happens at a3 format paper, a4 aint do this problem :/ no matter which tray
    Increasing fusing speed on techmode made IT better only for a few prints or it was just a luck:/
    Wysłane z mojego Mi 9 SE przy użyciu Tapatalka
  • piksel1983
    • Oct 2018
    • 38
    Re: C454e print problem
    Edit
    The lines starts everytime exactly from the same point and is allways at the same width.
    • Synthohol
      Certified Konica Expert
      • 5817
      have you replaced the developing unit? the gradient looks like crap nevermind the lines.
      • Hansoon
        • Sep 2007
        • 3380
        I don't know since you said you replaced practically everything, but first thing coming up in my mind seeing this: Crud under the transfer belt cleaning blade.....
        Hans
        • piksel1983
          • Oct 2018
          • 38
          DV's were swapped before print so they re crappy
          • piksel1983
            • Oct 2018
            • 38
            Hans
            ITB was changed and it didnt resolved the problem
            • femaster
              • May 2011
              • 1500
              For the hell of it, remove the black plastic guide piece that is mounted to the top of the ITB. It really looks like the fins from that are scraping the paper before the toner gets fused. If that takes care of the marks, at least you have an idea of where you need to concentrate.
              • Ziggy
                • Feb 2018
                • 721
                Try running a solid black and open the side door before it goes all the way through the fuser . Then check paper to see if its happening before fuser , at this point after carefully pulling out jam you could pull the transfer belt and see if the lines are on the belt
                • allan
                  RTFM!!
                  • 5462
                  Try the fuser speed adjustment. Wonder if it creates enough loop between the transfer and the fuser?
                  Whatever
                  • Max
                    • Oct 2011
                    • 557
                    It is a plastic guide that sits on the front of the transfer belt.
                    • Mr Bo
                      • Mar 2023
                      • 28
                      Hi piksel1983
                      In SM there is a mention of high voltage unit, try replacing it
                      • Max
                        • Oct 2011
                        • 557
                        Was the belt replaced with a different plastic guide? Just remove it completely for testing purposes.
                        • piksel1983
                          • Oct 2018
                          • 38
                          ITB was swapped, the guides were removed:/ nothing changed:/
                          • piksel1983
                            • Oct 2018
                            • 38
                            That was the first thing i have done. Jammed a3 paper between fuser and register roller. The scratch is before entering the fuser. The print can be removed by finger.
                            • piksel1983
                              • Oct 2018
                              • 38
                              Tkanks for reply and idea. Increased speed and set it at20 -max for thin paper. Printed well a few a3 papers and started scrating again:/
                              There's a loop in paper while entering fuser and exiting register roller.
                              This sh$+#t happens only at a3 paper, a4 is allways ok.
