bizhub 958 print quality issue. Faint image. Low image density.
  • subhashck
    • Mar 2020
    • 18
    Please refer the attached photos.
    Model: bizhub 958
    Counter: 97,000 only.
    Drum Unit & Developing Unit physically seems OK.
    Transfer Belt is OK. Cleaned the IDC (Front) Sensor.
    Earlier print was total blank. After manual Toner add in Service Mode the Print becomes darker, but not upto the mark.
    TCR is 7.14%
    N.B: The problem occurred when the Toner exhausted
    Kindly suggest
  • Gift
    • Mar 2011
    • 2459
    Re: bizhub 958 print quality issue. Faint image. Low image density.
    Guess I'd start with a new dev unit if the image looks faint on the drum, too (du a full bleed test and interrupt the print to see how it looks).
    • elmaligno
      Expert technician KM
      • Oct 2009
      • 302
      Model: bizhub 958
      TCR is 7.14%
      Kindly suggest
      Check the opening of the AIDC sensor window of the transfer belt, it is not working properly because the actuator (the white plastic part9 that has to open it rubs against the chassis. you have to install the modified one that comes with the BH950i or trim it a little.
      Field technician since 1994
      • otphas
        • Aug 2019
        • 127
        Maybe is weird answer, but to me happened this and CLEAR ALL DATA help.
          • 23010
          Genuine toner? =^..^=
          • subhashck
            • Mar 2020
            • 18
            Yes genuine Toner.
            • subhashck
              • Mar 2020
              • 18
              Dear all, thanks for your valueable suggestions and inputs!
              Please refer attached Table No, Level History 1 & 2 photographs.
              • tsbservice
                Field tech
                • 8064
                Your voltages are too high, you may have bad high voltage unit/1 (HV/1)
