Konika Minolta Bizhub C3320i Red / Blue Lines Solution
  • mirage
    • Apr 2023
    • 13
    I wanted to post the resolution that I found in troubleshooting my Konica Minolta Bizhub C3320i unit. When I initially got it, I had red and blue lines being printed, which almost looked like wide-ruled notebook paper from back in the day.
    This turns out to be due to the timezone, date, and time not being set. I performed the following procedures to fix it:
    -Tap the gear icon on the Home screen to go to the Utility Section
    -Tap counter within the Utility section
    -Tap 'Display Keyboard' in the top left
    -Press STOP button, 0, 0, Stop, 0, 1 (The Stop being the red stop key, the 0's and 1's are the virtual keys) to open the Service menu
    -Default service password is 9272927292729272 (9272 repeated 4 times in a row), then press END in the top right
    -Press Stop, 1, 1, 4, 4, C and this will take you to the Date/Time Area.
    -Simply choose your timezone, and then set the date/time accordingly, and Apply the settings.
    Your red/blue lines should now be gone. Figured I'd just document this in case it helps anyone else.
  • Toxic
    • 698
    Re: Konika Minolta Bizhub C3320i Red / Blue Lines Solution
    You just discovered well known and frequently phenomenon, "lines of shame"
    • mirage
      • Apr 2023
      • 13
      Aha! I just picked up this C3320i for $250 bucks, and Im trying to restore it and get it in a good place. It's been a fun adventure so far! I've put new toner carts and a new waste toner cartridge in it.
      I'm now trying to get the latest and greatest firmware and also trying to see if there's a way to lower the initial power draw when the unit first powers on.
      • Toxic
        • 698
        Initial power draw is normal for all copiers because of warming up process when fuser lamp(s) is active.
        I don't think you can do anything about that and why is that problem anyway, that little thing don't consume much power after all?
        Ps:golden rule, don't try to fix things if they work
        • mirage
          • Apr 2023
          • 13
          Well when I got it the magenta toner was completely gone and my waste toner was full. There was a firmware issue that addresses that, and I'd rather be safe than sorry there, or be out a toner that I just bought.
          • rrrohan
            • Sep 2011
            • 1977
            most noobs forget to set the time even if the current reading is correct.
            • ionutkok
              • Nov 2012
              • 24
              • Krusty
                • Mar 2024
                • 2
                Thank you for this solution. We just got a bizhub C650i and our technician couldn't figure out the problem after assembling the unit. I couldn't wait much longer as I have a lot of printing so I searched and joined this group.
                Thank you again! much appreciated!
                • mirage
                  • Apr 2023
                  • 13
                  I'm glad the advice here helped you Krusty
