SSL not available in open API
  • jamielex73
    • Apr 2023
    • 1
    [Misc] SSL not available in open API
    Hi,
    I'm working on a 257i and i just cannot enable SSL on open API - option is greyed out.
    I have a self signed cert and PKI is set to use ssl in admin and user mode.
    Dvice has been restarted several times.
    have 3 other 257i machines, all on same firmware, same settings all working fine.
    Is there something drastic i'm missing?
    Can it be enabled from device control panel (I am working remotely and remote panel doesn't give me access to the administrator settings).
    Thanks in advance for your help.
    Jamie
  • and
    • Oct 2011
    • 99
    Re: SSL not available in open API
    Check with OpenAPIApplicationManager if some application is installed. Remove everything except the marketplace.
    Originally posted by jamielex73
    Hi,
    Jamie
    • tsbservice
      Field tech
      • 8053
      Try to do network reset in service mode - system 1 - initialization - network
