C227. parts black DV unit
  • GeorgeBest
    • Jul 2009
    • 526
    Hi,
    Somebody knows the part nm of 2 gears driving from developerunit Black, see picture . . .
    Thanks in advance
  • tsbservice
    Field tech
    • 8064
    Re: C227. parts black DV unit
    No part numbers, only whole unit. Try to find used one or Aliexpress.
    • Toxic
      • 698
      Replace whole unit, it is not so expensive and change toner brand.
      I have seen 2 times failure like that and in both cases not OEM toner was used.
        • 23010
        Often gear failure on developing units results from leaky developer seals. If you don't address the leaky seals, the gears won't last long. Best to replace the unit. =^..^=
        • allan
          RTFM!!
          • 5462
          Parts should be the same as DV512 DV313 or DV 316.
          Whatever
