SPI Check NG cant load firmware on Bizhub C558
  • SAR
    • Jul 2009
    • 205
    This problem started when we tried to update firmware and got a NG on all of the different firmwares.
    Tried a new HDD, data clear, tried to update firmware through ISW, no luck.
    Ran the self diagnostic and got a SPI Check R/W Check NG message.
    I submitted a problem request to KM and they said to replace MFP Board.
    I know it's a long shot, but wanted to check on here first to see if anyone else has had this issue and had any ideas to try before replacing the MFP board.
    Thanks!
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: SPI Check NG cant load firmware on Bizhub C558
    try reseating the memory, boot to a firmware stick but select machine and type. make sure there isnt FF in both places you must enter he machine and type.
    its worth a look.
    • tsbservice
      Field tech
      • 8053
      Try reset tool before MFPB.
