Bizhub c250i magenta stripes and grainy color
  • occus
    • 337
    Hello everyone.
    I have a c250i which prints light magenta stripes or areas when printing. I visited the customer 2 weeks ago and exchanged the drum, after that the problem was solved. I could see that the cleaning roller was partial full of toner.
    Now the customer has called again that the same problem has appeared.
    What I was able to determine was that the printout is strangely grainy in color, but not in black.
    Someone have an idea? DV and Belt looks visually flawless. I guess laser or HV.
    Counter: 10k black 27k color
  • copyman
    Owner / Technician
    • Sep 2005
    • 4723
    Re: Bizhub c250i magenta stripes and grainy color
    Originally posted by occus
    Hello everyone.
    [ATTACH=CONFIG]58176[/ATTACH][ATTACH=CONFIG]58177[/ATTACH][ATTACH=CONFIG]58178[/ATTACH][ATTACH=CONFIG]58179[/ATTACH][ATTACH=CONFIG]58180[/ATTACH]
    Strange with a low meter you would have to replace anything. Only thing that would make sense is aftermarket toners?
    • Gift
      • Mar 2011
      • 2459
      perhaps bad luck with the DV unit - are toner and drum original or aftermarket or something "modified"?
      • occus
        • 337
        Only original consumables.
        The customer told me the strips appeared on the first print on Monday morning, but everything was fine on Friday. Well today the stripes are suddenly gone again. Only the grainy print remained.
        • Gift
          • Mar 2011
          • 2459
          Hard to judge from the sample photos - running another gradation adjustment and using color copy paper might archieve better solids.
          • tsbservice
            Field tech
            • 8020
            Occus can you send me MML via PM. I would like to check it.
            • tsbservice
              Field tech
              • 8020
              Is this KM or Develop because I can see in S1 it thinks is Develop Ineo
              • occus
                • 337
                yes, labeled as ineo.
                • Max
                  • Oct 2011
                  • 561
                  Check the drum and charge voltages in service mode. See if anything is abnormally high or low.
                  • tsbservice
                    Field tech
                    • 8020
                    Vdc-Y is too high at 666V normally should be 300-500V.
                    Can you try another Y drum to see any difference?
                    Also your CCD Check for clamp/gain are higher than normal, mine are way low.
                    • mIRCelam
                      • Oct 2023
                      • 2
                      Hi, I have a similar problem. Did you resolve youre problem? And if you did, how did you fix it?
                      • occus
                        • 337
                        No, ticket ist open... we are waiting for customer's call.
                        A few days ago I prepared a new c250i and it shows the same problem and additonally the cyan toner goes to 0% after a few prints.
                        Device repackaged and sent back. I have no time to repair so many new devices.
                        • mIRCelam
                          • Oct 2023
                          • 2
                          • occus
                            • 337
                            I would particularly like to mention that the print quality of the new device was initially completely ok. Only after a few fullpattern cyan prints did this grainy print appear. It was a test to see if the TCR value falls.
                            This one showed strange behavior. I expected the value to drop but after about 6.2% it jumped up to 8% and that's when I decided to save my time. KM will not pay me for warranty work.
                            So you might think that the DV Unit is to blame. But on the other device there are all 3 colors and that would be a very big coincidence...
                            • Techman63
                              • Mar 2022
                              • 10
                              Hi,
                              I had this problem too. I changed the Magenta Drum. Without success.
                              Than I changed the Dev Unit. That was the problem.
