Konica/Minolta Board Repair
  • Tata
    • May 2008
    • 42
    Does anybody know where I can send boards for repair, other than Konica, that is cheap fast and good? Thanks. Any info will help.
  • brent
    • Nov 2008
    • 1214
    I have had good luck with hytec repair
    www.hytecrepair.com
    I hope that link works.
    they can send out boards in advance exchange as well
    brent
    • Raymondd
      • Jan 2008
      • 108
      I've used Hytec before (years ago). They were pretty good. Here's a link...
      Circuit Board Repair by Hytec Dealer Services, Inc.
      • Tata
        • May 2008
        • 42
        Thanks for the info. I used them before but they screwed up with one order and I haven't use them since. I guess I'll try them again.
        • HB_AL
          why not do a certificate in electronics so you then can repair a board for the cost of a cuppa coffee, might take some time but is well worth it
          • Tata
            • May 2008
            • 42
            Thanks HB AL
            Over the years I have repaired many boards on the old models, now is more complicated because the new boards require more sofisticated equipment to find the components that have failed. I have a degree in electronics, but it is almost impossible to find the components you need, if you were to find them. They also use robots to solder most of these boards. I rather have the guys that have all the equipment do it for me. Thanks anyway.
