750i it reboots
  • romario
    • Jun 2020
    • 193
    750i it reboots
    hello everyone, I have this problem on the 750i, the machine restarts 6, 7 times a day, has anyone happened to it?
    The machine is updated to the latest firmware version.
    thanks
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: 750i it reboots
    if its rebooting because of an error it should show in the MML
    find code, check manual.
    if no codes monitor wall outlet voltage. these newer models with 3.3v as a sensor reference instead of the old 5v if there is neutral to ground voltage it can confuse the hell out of the copier.
    they are so much more sensitive to electrical fluctuation than previous series.
    also unplug network for a bit see if it still random reboots.
    good luck.
    • romario
      • Jun 2020
      • 193
      Re: 750i it reboots
      good luck.
      The voltage has already been verified, it is in the correct range, the machine has 250k, it does not show an error code
      thanks
      • allan
        RTFM!!
        • 5462
        Re: 750i it reboots
        Synthohol means the code that is logged in history. There must be something. Otherwise check the instantaneous power loss counter to see if it coincides with the reboots.
        Whatever
        • tsbservice
          Field tech
          • 8052
          Re: 750i it reboots
          Replace CPU board.
          • tech51
            • 846
            Re: 750i it reboots
            Check dipswitch 163 is set to hex 0. This turns off the auto reboot on error. If there is actually an error occurring the machine will hopefully not reboot and display the code.
              • 14972
              Re: 750i it reboots
              I recently had a machine that would reboot randomly but when I brought it back to the shop to monitor, it seemed to only do it when it went into low power mode. I turned off wake by touching control panel and that seems to have solved it. I followed up with customer and it is working properly.
              Worth a shot. If that doesn't work, I would definitely follow tsbservice's advice and replace CPU board.
              • romario
                • Jun 2020
                • 193
                Re: 750i it reboots
                The problem is in the CPU. I have already ordered one at km. I'm waiting for it to arrive to change. I am reporting thanks for your help
                thanks
                • romario
                  • Jun 2020
                  • 193
                  Re: 750i it reboots
                  I changed the cpu and the machine is working perfectly and it doesn't restart. thanks for your comments
                  thanks
