C454e code C-F902
  • copyman
    Owner / Technician
    • Sep 2005
    • 4712
    C454e code C-F902
    Machine had code C-F902 and would not reset. After trying some of the things in serv man for that code still wouldn't reset. Ended up using reset firmware and everything was fine, all meters, serial # all correct after using recover data tab. 6 hours later customer called and said code is back and will not reset by turning power off and back on. I suspect MFP board but don't have one to swap. I would think if MFP board it would be a hard failure and not reset with reset tool?
    Only 65k clicks on meter.
    Any ideas appreciated.
    Thanks in advance
  • KMFLT3CH
    • May 2017
    • 240
    Re: C454e code C-F902
    This is what I can find, hope it helps.
