Papercut stuck in KM trying to install printix
  • cube10025@gmail.com
    • Aug 2022
    • 55
    I am trying to install a new machine with printix, for some reason it refuses to install. Says papercut installed!?
    I have formatted logical the drive reset the machine why is still papercut there!? Or is it a false positive? Will try physical format (last thing to try)
    Error codes
    23:25:23    Install failed:Result error, infoCode: 2 , error: 3, 'AuthenticationFunction' (FAIL 20388a1a-c9fd-4ba5-8692-b23bb3422fa5)
    23:25:16    Starting install (SUCCESS)
    23:25:13    Existing authentication app found: 'PaperCut Authentication' (FAIL)
  • serwisant11
    • Feb 2021
    • 5
    Re: Papercut stuck in KM trying to install printix
    Check the loadable drivers in the service mode.
      • Aug 2022
      • 55
      Why? There is no card reader at the moment, and dose this not get removed once you run initialization?
      • Synthohol
        Certified Konica Expert
        • 5846
        afaik paprercut can only be removed with papercut.
          • Aug 2022
          • 55
          Yes I am calling papercut tomorrow to get it removed, I guess papercut is not removed when running initialization and formatting harddrive!?
          • tsbservice
            Field tech
            • 8020
            What exactly machine we are talking about?
            Model please.
            Your best bet would be to do initialization not format
            • DelawareJim
              • Jan 2008
              • 65
              We've had Papercut on C3850, 4050/4750, and a c454e. Had to format the hard drive on each.
                • Aug 2022
                • 55
                Model please.
                Its c458. Done both several times in different order. First try was initialization.
                  • Aug 2022
                  • 55
                  • rrrohan
                    • Sep 2011
                    • 1977
                    or use API Manager program to delete it
                    • Scope
                      • Feb 2022
                      • 16
                      Change authentication device from external MFP to OFF, Restart
                        • Aug 2022
                        • 55
                        It already is.
                        I have tried for some reason the program wont connect. I have vers 4.1
                        • Konicatech
                          • Feb 2016
                          • 131
                          Open API Tool/Manager will remove it provided the tool is configured properly.
                          Otherwise set the device up on Papercut and remove it from there.
                            • Aug 2022
                            • 55
                            Finally was able to remove papercut used API manager had to disable openapi and ssl in order to get in but finmalt it worked papercut gone and printix installed
                            • rrrohan
                              • Sep 2011
                              • 1977
                              Originally posted by cube10025@gmail.com
                              It already is.
                              yeah last time i used it to remove marketplace screen saver (which it just reloads so was waste of time) was super janky and kept crashing.
