C250i Jam Code 99-14
  • ottarf
    • Oct 2015
    • 4
    Hello!
    Anyone seen jam code 99-14 on a C250i? Can't find it in the SM... It appears during initialization / image stabilization. The case started with low density in black, and soon escalated into this scenario. Toner density values seem normal. There was also a couple of C45-01, but with no information on the controller jam code I don't know if it is related...
  • copytechtrouble
    • Nov 2020
    • 112
    Re: C250i Jam Code 99-14
    the latest version of the manual (version 2.2) has it listed as 'Controller JAM (image stabilization timeout)'
    I've added the relevant sections of the manual below.
    • ottarf
      • Oct 2015
      • 4
      [ATTACH=CONFIG]58427[/ATTACH]
      [ATTACH=CONFIG]58429[/ATTACH]
      Thanks a lot! Now I at least know what I'm dealing with
      • joelcarrara
        • Jan 2017
        • 50
        We just had this code pop up. We're you able to resolve it?
        • Black Cloud
          • 176
          Pull the laser unit from the machine and clean the polygon mirror. You will find half of the surface is clouded. Then run gradation.
          I have one machine that needs this about every 6 months.
          This is the fix for your issue.
          Net+ PDI+ @Remote
          • copyman
            Owner / Technician
            • Sep 2005
            • 4785
            Good detailed advice.
            • joelcarrara
              • Jan 2017
              • 50
              Thanks so much! We'll report back.
              • apollo
                • Mar 2008
                • 191
                I had brand new C300i causing same issues, changed laser unit under warranty.
                • joelcarrara
                  • Jan 2017
                  • 50
                  Update: It's def the laser unit. Confirmed by KM. Good call by black cloud, copyman, and apollo. Thanks to all for your advice! It is covered under warranty. We are going to inspect the polygon unit during replacement.
