Konica Biz Hub C284e memory upgrade question
  • tonerjockey
    • Apr 2014
    • 573
    Hello guys, happy Friday.
    customer wants to increase the memory. if this is the same as the C554e, there is a HDD and 2 DIMM sticks.
    i have asked them to print a config hoping that it will show the current memory level.
    my question, if they want to print larger jobs, or without a lag time, is it the DIMM that needs to be replaced?
    they told me the C554e needed a larger memory back when they purchased it and the Konica dealer sent them a 320 gb HDD.
    thank you very much.
  • Synthohol
    Certified Konica Expert
    • 5922
    Re: Konica Biz Hub C284e memory upgrade question
    in admin mode set spool jobs to HDD.
    done.
    the extra ram helps with apps, i never saw an increase of ram improve printing when the jobs spool to the copier HDD.
    • tonerjockey
      • Apr 2014
      • 573
      oh cool. thank you. i was wondering about that.
      i will give that a go. I really appreciate it.
      have a nice day.
      • Synthohol
        • 5922
        also you can turn off other things not being used like if there are no MACs you can disable appletalk and probably IP6 too. this will use less memory.
        • Hansoon
          • Sep 2007
          • 3402
          done.
          Where to find that setting Synth?
          Hans
          • Synthohol
            • 5922
            ADMIN, PRINT, BASIC.
            • tonerjockey
              • Apr 2014
              • 573
              thank you very much syntholol for the page.
              ill let you know. the customer is considering pulling the plug at this point. sadly.
              have a nice day.
