App tab on screen
  • copyman
    Owner / Technician
    • Sep 2005
    • 4664
    App tab on screen
    How can I remove the App tab on the C458 basic home screen? What type of Apps is it for? When I touch it message is "connecting to Cox Campus"
    I've checked admin & serv modes. Didn't see anything unless I missed it.
  • techsxge
    • Jan 2022
    • 660
    Re: App tab on screen
    Admin Webpage:
    System Settings -> Standard Settings for Home screen
    This is translated from german Machine, i hope this is correct.
    If it is not there, maybe you can turn off something inside bizhub marketplace?
    • tsbservice
      Field tech
      • 8002
      Utility]
      [Administrator Settings]
      [System Settings]
      [Custom Display Settings]
      [Main Menu Default Settings]
      Configure shortcut keys that are displayed in the main menu.
      Select the number of the main menu key to which you want to assign a shortcut key and configure a function to be assigned. [Main Menu Key 1] to [Main Menu Key 11] are assigned to the first screen of the main menu. These keys should be assigned to frequently used functions.
      • techsxge
        • Jan 2022
        • 660
        Utility]
        [System Settings]
        thanks tsb, that is what i was trying to say
