c659 cyan lines
  • Hap
    • Jan 2017
    • 34
    c659 cyan lines
    lines in feed direction only in cyan replaced cyan drum and transfer belt cant be the laser would that not make kight lines
  • tsbservice
    Field tech
    • 8053
    Re: c659 cyan lines
    Sample please.
    • elmaligno
      Expert technician KM
      • Oct 2009
      • 302
      Re: c659 cyan lines
      it is important to see an example, because this can be done if the initial configuration has not been done correctly.
      Field technician since 1994
      • Synthohol
        Certified Konica Expert
        • 5892
        Re: c659 cyan lines
        i was getting LOS vibes too
        cant wait to see sample.
        • Hap
          • Jan 2017
          • 34
          Re: c659 cyan lines
          sorry was having trouble posting image
          • tsbservice
            Field tech
            • 8053
            Re: c659 cyan lines
            May be developing unit itself.
            • Hap
              • Jan 2017
              • 34
              Re: c659 cyan lines
              well its an image unit with built in dev changed exactly same
              • tsbservice
                Field tech
                • 8053
                Re: c659 cyan lines
                Sorry didn't read well it's high speed unit with IUs. What's paper weight I would experiment with different papers/weight settings.
                • allan
                  RTFM!!
                  • 5462
                  Re: c659 cyan lines
                  The C659 is a POS to start with...
                  Does that cross direction band move or stay on the same place every print?
                  Sure its only on Cyan?
                  Its got lines in the feed direction that looks like a buggered charge roller. You can still get to the charge roller with a damp cloth to try and remove some of the dust collected on it.
                  No idea what is causing the cross direction band on that sample you posted.
                  Whatever
                  • Hap
                    • Jan 2017
                    • 34
                    Re: c659 cyan lines
                    Its the feed direction lines that are the issue cross bands have gone away,it has to be the imsge unit i cleaned the print head no diff and flashed to latest versiom its ginda wierd on the print the cust was doing looked like a light area but lines up perfectly with cyan dark bandsKM8D6E0223060913010.pdf
                    • allan
                      RTFM!!
                      • 5462
                      Re: c659 cyan lines
                      Did you replace the cyan IU with a new or used unit? You only show the cyan half tone and not the rest.
                      Whatever
                      • Hap
                        • Jan 2017
                        • 34
                        Re: c659 cyan lines
                        was a brand new iu all the other colours looked fine
                        • SAR
                          • Jul 2009
                          • 205
                          Re: c659 cyan lines
                          That looks a lot like the lines you get from dirty print heads. I know you cleaned the print heads, but I have had several machines over the years where the lines get badly baked on the print head. I had one recently where I had to run the cleaning wand soaked in windex between 50-100 times through the print head and then follow up with a dry cleaning wand to remove any residue. It's worth a try and would only take a few minutes.
                          • allan
                            RTFM!!
                            • 5462
                            Re: c659 cyan lines
                            Taking the laser out in that case would be a good option.
                            Whatever
                            • Hap
                              • Jan 2017
                              • 34
                              Re: c659 cyan lines
                              Yup was the laser took it out and cleaned it perfect now i thought laser would only cause light lines thanx for help
