Konica MInolta Bizhub C458
  • GeorgeBest
    • Jul 2009
    • 526
    Got this problem with the developer black unit, see picture
    customer complained, there were black spots an images on the prints
    So, saw this problem when took out the developer unit, ordered a new one, however the problem came back, also with the new one
    Anybody"s a tip for what's causing this, it runs sometimes goor for let's say about 100 prints, and then it returns
    The drum unit look ok
    • 8144
    Re: Konica MInolta Bizhub C458
    Originally posted by GeorgeBest
    Thanks in advance[ATTACH=CONFIG]58607[/ATTACH]
    Compatible / non genuine toner causes this issue.
    • Toxic
      • 697
      What is drum life?
      Worn drum can cause this no matter it looks ok visually.
      • ltdiniz
        Supervisor de Campo
        • Mar 2021
        • 98
        The position of the cylinder spacing on the front of the DR313K has probably been changed.
        Check it out okay.
        • L0rdC
          • Feb 2021
          • 82
          Check it out okay.
          That's it, inclined cylinder
          • tsbservice
            Field tech
            • 8016
            +1 to what @ltdiniz said.
