Konica 7245 F26-3
  • xcopy
    • Mar 2009
    • 57
    Konica 7245 F26-3
    machine was due PM so changed dev and developer assembly.
    Went to do L-Detect and the machine does not run it just comes up with value of 005.
    The main motor should be running so changed driver board, still the same.
    Any ideas? Dont really want to order main board yet incase its some thing easy to fix.
  • kmcopytech
    • Dec 2007
    • 141
    L-Detect code 0005,
    1\Developer PM counter reset;
    2\supplies toner.
    • PeterG
      • Jul 2008
      • 177
      Your main motor M1 is shagged.
      If you remove it you will find that the motor windings are fractured where they connect to the motor pcb.
      • DCPS
        • Mar 2008
        • 116
        I didn't know that there is such a copier 7245??? I thought there were either 7145 or 7222/28/35. In the second case it is probably the M1 the problem for 26-3 but in the case of 7145 i never had similar problems.
        • pepper38_cnd
          Field Service Manager
          • Aug 2005
          • 1075
          Before you go wild changing things Clean the sensor in the drum carriage if it is dirty L-Detec will not run you will get an instant 005 or it will make a short attempt and return 006. Clean it with alcohol even if it does not look dirty.
          Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
          Now into Ip TV KODI Boxes
