C250i No yellow on rear side of page
  • tsbservice
    Field tech
    • 8012
    #31
    Re: C250i No yellow on rear side of page
    Originally posted by Mildred
    I had an issue the other day when changing a drum.
    When I released the pressure of the developer I lost magenta on the rear side of the page. Just like your yellow.
    I stopped the print and checked image on the drum and transfer belt. Found it was not transferring developer from developer to drum.
    My TCR levels were correct around 6 to 7.
    What I found was the developer ! Just above the developer roller there is a black cover that goes the length of the developer roller. It slides in and clips into place. From a quick glance it looks in place but is loose and held in by tape if I recall. Not properly clipped in. When this guide is out of position it alters the developer to drum spacing causing faint prints front to rear.
    I have attached a picture of a developer with a arrow pointing to the guide I am referring.
    Hope this helps, if it the same as my issue I had.
    regards
    This is very interesting, thanks for heads up Mildred!
    • joeywatt
      • Oct 2023
      • 2
      #32
      I think you should check the patches. That worked for me too. safety pool fencepool fence
