DI 450 parts
  • CopyDocABM
    • Jun 2016
    • 5
    DI 450 parts
    Hello everyone I'm looking for some parts that are no longer available I need a aidc sensor part number 1136-0107-01 and anti spill mylar 1013-5524-01 any help would be much appreciated I know it's a shot in the dark I figured I'll take it thanks again Kevin
    Re: DI 450 parts
    I would suggest posting this in this forum: https://www.copytechnet.com/forums/the-parts-room/
    • Hansoon
      • Sep 2007
      • 3391
      Re: DI 450 parts
      If nobody else jumps in, I still have loads of the Antispill Plate 1013-5524-01. Can send one or more to you. You would have to carry the postal charges Germany>USA though.
      AIDC sensor 1136-0107-01 is unknown in the manual. According to my inventory system, it should be #1149-0107-01
      Hans
      • CopyDocABM
        • Jun 2016
        • 5
        Re: DI 450 parts
        Thank you Hansoon for correcting my part number. I will check into how much the postage is and let you know about the blade thanks again.
        • CopyDocABM
          • Jun 2016
          • 5
          Re: DI 450 parts
          Hello everyone I have cleaned the sensor replaced the mylar and the developer The error code C-OF24 came back i can see a void across the developer roller doesn't fill in when i rotate it. i think the dv unit is bad. putting this out there to see if anyone has seen it or might have the DV unit. I will find the number and add to the post, thanks in advance.
          • Synthohol
            Certified Konica Expert
            • 5857
            Re: DI 450 parts
            probably just dust behind the doctor blade.
            those units have to be really vacuumed well sliding a slice of a transparency along the doc blade whole turning and vacuuming when changing developer..
            lol i have an old PI 5500 fiery if you can find an interface board!
