IC 601 error sc 40 - 008
  • oommiiddaann
    • Feb 2012
    • 34
    [Error Code] IC 601 error sc 40 - 008
    hello dear Techs.
    i've a ic601 that shows controller error sc 40 - 008 every 2or 3 prints an it has to restart by restart button.
    how can i resolve that?
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: IC 601 error sc 40 - 008
    Code
    40-008
    Classification
    Fan abnormality
    Cause
    The lock of FPGA fan (FM) is detected.
    Measures to take when alert occurs
    IC stops immediately.
    Estimated abnormal parts
    • FPGA fan (FM)
      Correction
      Turn OFF/ON the power switch of IC.
      biz hub PRESS Car's/CAP/C70hc/Car's/PRO COL K TROUBLESHOOTING > 5. TROUBLESHOOTING (IC-601)
      K -355
      Note
    • The message "Please turn on power again" is displayed on the touch panel.
    Solution
    1. Turn OFF the power switch of IC and reboot it after 10 seconds.
    2. Check that the FPGA fan (FM) is rotated.
    3. Remove foreign materials if any.
    4. When there is no foreign material, replace the FPGA fan (FM).
    Faulty part isolation DIPSW
    Control while detached
    • oommiiddaann
      • Feb 2012
      • 34
      Originally posted by Synthohol
      Code
      40-008
      Classification
      Fan abnormality
      Cause
      • FPGA fan (FM)
        Correction
        K -355
        Note
      Solution
      Thank you for your fast reply synthohol 🙏🌹
      • Synthohol
        • 5824
        NP, there are only 3 fans in that box so it shouldnt be too hard to clean
        good luck.
