Bizhub 4750i code- C - 9701
  • krm
    • Aug 2009
    • 233
    57K print - scans 3K
    Manual says cable break between CIs and base board.
    Code comes on at power up. Everything looks OK visually with the ADF/hinges, etc. Anyone run into this? Not seeing much on this model with that code.
    Thanks for any help in advance.
  • hobbele
    • Nov 2019
    • 38
    Re: Bizhub 4750i code- C - 9701
    We currently have this error very often with the C3350i
    A trouble reset is usually sufficient here, sometimes we also exchange the CIS and the flat cable...
    But some of the machines come back with the error...
    I hope someone has an advice
      • 37487
      You will get a lot more replies if you had posted it in the proper forum.
      • krm
        • Aug 2009
        • 233
        Trouble reset did not work. We are waiting on the flat cable. Thank you for the input.
