On the i series if you replace the control panel you will end up with a C-C164 code and firmware cannot be updated but instead shows firmware error.
Obviously the swapping of the panel caused the code, there must be a procedure when replacing that tft display or any other peripheral hardware but I have not managed to find it on MyKonicaMinolta.com. Advice appreciated.
