KONICA MINOLTA C258-C308 firmware
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5876
    Re: KONICA MINOLTA C258-C308 firmware
    times like this i setup scanning on my laptop and see if its the machine or their network\PC security
    what operating system?
    if its the "home" version of windows scanning is a PITA.
    please post the scan error from the log.
    can the folder its being scanned to be reached from another PC? \\xxx.xxx.xxx.xxx\foldershared?
    are you sharing the exact folder or a subfolder under the share?
    was the specific scan user added to the permissions of the folder shared? with full permission?
    without a failure code we are grasping at straws.
    • xender79
      • Nov 2009
      • 47
      MYBOX에서 공유된 파일을 확인하세요.
      <기능 버전>
      소프트웨어 스위치 설정에 대하여
      스위치 번호: 25
      HEX 할당: 10 -> 기능 버전 2.0
      HEX 할당: 20 -> 기능 버전 2.1
      HEX 할당: 30 -> 기능 버전 2.2
      HEX 할당 : 40 -> 기능 버전 3.0
      HEX 할당: 60 -> 기능 버전 3.2
      HEX 할당: 70 -> 기능 버전 3.3
      HEX 할당: 80 -> 기능 버전 3.4
      HEX 할당: 90 -> 기능 버전 4.0
      HEX 할당: A0 -> 기능 버전 4.1
      HEX 할당: B0 -> 기능 버전 4.2
      Originally posted by M1963
      인사합니다.
      smb 2.0을 지원하는 펌웨어 KONICA MINOLTA C258-C308이 필요합니다.
      감사합니다.
      • insigniawales
        • 29
        • Synthohol
          • Mar 2016
          • 5876
          #19
          best to print from the app imho but is there any security on the machine at all?
          btw if the copier hardwire is on the same subnet as their wireless network they can simply use that and forget about airprint and print by IP..
          just my .02 sounds like copytrack or something else restricting it unless they have the wrong driver from a previous model?
