Konica Minolta c227 abnormal
  • Daniele
    • Jun 2019
    • 15
    Hello everyone, sorry for my english but i'm using the translator. I have a konica c227 from a customer, practically the printer after 5 minutes does not print and does not photocopy anymore because it goes away In "stop printing" . I forgot to see what kind of F/W the printer has. Has anyone ever had this problem?. I would like to try an update. Can you please send me the latest FW.
    D I did 2 types of procedures, I initialized from system 1 and nothing changed, I tried disabling and re-enabling the hdd and nothing changed. Thank you in advance.
  • aberock
    • May 2022
    • 104
    Re: Konica Minolta c227 abnormal
    Originally posted by Daniele
    [ATTACH=CONFIG]59065[/ATTACH]
    Hi ,
    Try to check drum life and other part counter .
    Clear all part counter and replace drum chip if need . This should be work .
    Thanks.
    • Daniele
      • Jun 2019
      • 15
      Originally posted by aberock
      Hi ,
      Thanks.
      But should the wording of the empty drum appear? Anyway how do I clear all the counters. Thank you for answering me.
      • tsbservice
        Field tech
        • 7916
        System 2 set switch 230 to 00. That should show up consumables life. More than likely it's stopped due to life stop settings in service mode. PM me if you don't know where and what to look for.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4534
          Make sure life stop is off in "enhanced security" mode.
          • Daniele
            • Jun 2019
            • 15
            Hi guys, THE LIFE STOP was active. luckily. Thanks Have a good day
            • copyman
              Owner / Technician
              • Sep 2005
              • 4534
              Glad to help. Good to hear it was something simple.
              If you are happy with the help you received please consider making a small donation to help keep this website active.
              Best of luck
