KM C458 Web browser licence issue
+ More Options
Posts
  • Brad6784
    • Mar 2015
    • 84
  • Synthohol
    Certified Konica Expert
    • 5888
    Re: KM C458 Web browser licence issue
    you are doing it wrong
    you must first disable the fiery (controller 0)
    now hook the LAN line right to the copier let DHCP work.
    once it on the network NOW you can enable the web browser without all the hassle. should work in seconds the normal way with auto license.
    there is a specific procedure that must be done in the right order or it just wont work.
    lemme find it, i have it somewhere..
    this will work...
    Originally posted by Markks
    Setting Up a IC-416 on the new C308, 368, and the C458, 558 ,658
    First is to set the machine up as though it does not have a Fiery.
    Give the machine an IP and DNS so you can activate the web browser.
    To activate web browser
    1. Admin
    2. Network to pages three
    3. Web browser setting (select on) if you are able to get to the web the machine will restart when is it is done. If not then follow the next step.
    To Activate web browser without internet
    1. Retrieve activation code by going to : http://lms.konicaminolta.com/activate .
    2. In Administrator Mode
    a. Go to Network Settings
    b. Go to Page 3
    c. Go to Web Browser Settings
    d. Input activation code
    Now that you have web browser activated go to service mode
    1. System 2
    2. Image controller ( set to controller 1)
    3. Make sure the machine is set to DHCP in the network setting before turning off the machine.
    Now plug the network cable into the Fiery and the crossover cable from the Fiery to the machine (even if you are going to us two network drops you still want to first setup the Fiery using the cross over cable the first time)
    Turn on the Fiery and wait about three minutes before turning on the MFP. The MFP will come on and tell you to turn on the controller and it may after the turn on controller massage goes away tell you that it could not connect to the controller. That is ok at this point restart the MFP one more time. (DO NOT RESTART THE FIERY). When the MFP comes back on the Fiery should give the machine an IP. If you look under device info the IP should end in .2 at this time you can now program the Fiery. If you are going to use two network drops then you can now remove the cross over and program the MFP when you finish programing the Fiery.
    If you find that the Fiery button is missing under the menu screen here is the steps to get it to show up.
    1. Got to Admin
    2. System Settings
    3. Go to page three
    4. Custom Display Setting
    5. Main menu default setting
    6. Main menu key 5 (turn on Fiery button)
    • Brad6784
      • Mar 2015
      • 84
      • jotunn
        • 634
        Probably you need to make licence initialization again, but now with your machine true serial number.
        First check if your machine have current date&time set, then send me serial number and request code taken from CE mode -> [Stop][9] -> [Licence management] -> [Request Code]
        • Brad6784
          • Mar 2015
          • 84
          This is what I think it may need, that would be extremely helpful, I have the request code here, I shall PM it to you now, thank you so so much!!
          • Brad6784
            • Mar 2015
            • 84
            This problem has now been resolved by the very kind and helpful Jotunn.
            If anyone has this problem, as Jotunn says, the licence needs to be initialised with the machines serial number, then the browser enabled straight away.
            Thank you Jotunn and everybody else, as always the forum has saved me yet again.
            Thanks everybody, have a great week!
            • ltdiniz
              Supervisor de Campo
              • Mar 2021
              • 98
              @Jotunn and others here as an example @Synthohol...
              They are certainly a differential in the forum.
              Congratulations and good week to all.
              • KentHammer78
                • Feb 2021
                • 1
                I have Konica C658 that I need to enable the Web browser function to add Papercut. When I try to enable this I'm asked to input a license code which I assume can be generated in the service mode?? I've tried to generate code on the Konica LMS Website but this says the MFP Serial number is invalid.
                Any ideas anyone???
                • jotunn
                  • 634
                  Try to connect the machine to network with Internet connection, configure proper DNS servers and gateway, then:
                  1. Tap [Utility] - [Administrator Settings] - [Network Settings] - [Web Browser Setting] - [WebBrowser Usage Settings].
                  2. Select [ON], then tap [OK].
                  In the meantime you can send me serial number of this machine.
