Toner spots on all printouts
  • cruis
    • Jul 2023
    • 13
    I have a c258 here that makes spots on each side. I have tried cleaning everything but the stains are still there. Can anyone give a hint based on the scan?
    thanks and greetings
    SV-viks kon23080208250.pdf
  • Gift
    • Mar 2011
    • 2459
    Re: Toner spots on all printouts
    Poor sample - is it a repeating pattern in running direction?
    • cruis
      • Jul 2023
      • 13
      Oh yeah, that picture was trash. I have now attached the scan as a PDF. Every page looks the same, the error is always in the same place.
      • Gift
        • Mar 2011
        • 2459
        That's 100% a repeating pattern - you can test A3, too and it should be visible more times - probably BK drum or fuser
        • cruis
          • Jul 2023
          • 13
          Thanks, I will test that. But if it were the fuser, then the spots should also take on the same color after a full color test print?
          • Gift
            • Mar 2011
            • 2459
            Yeah if you print a few pages full coverage cyan for example and then a white page the marks should appear cyan. If the BK drum is the cause you should also see the marks on the drum surface during a close inspection.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4775
              If repeat image is only black then can only be black drum.
              Not sure if I understood, are you saying defect is on both front and back of page?
              • Toxic
                • 698
                Measure distance between marks, if it is about 95mm than drum is damaged.
                • cruis
                  • Jul 2023
                  • 13
                  I'd like to give feedback. The replacement of the drum has brought success. Thanks for the support!
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4775
                    Thanks for follow up. Glad to help.
