My machine konica 226 Lower print issues
  • zawmyo201210
    • Oct 2022
    • 51
    [Misc] My machine konica 226 Lower print issues
    My printer Konica 226 is producing poor quality images, so I have ordered a new Developer powder(DV116) and a new drum.
    In the same way, the quality is not as good as before. Bad type of pounder powder? I want to know.
    The laser units have been thoroughly cleaned. Please advise me.
    developer
  • Toxic
    • 698
    Re: My machine konica 226 Lower print issues
    Check transfer roller if it sits ok and is contact ok.
    If copy quality was the same (bad) just after replacing parts then toner,drum and developer is not a problem.
    Also check is fuser roller lever is in the pressed position.
      • 23008
      I think it would help to post some image quality samples and the yield on the machine consumables. I'm not totally averse to guessing, I need something to base opinions on. =^..^=
      • zawmyo201210
        • Oct 2022
        • 51
        I understand what you are saying. The current bug has also been uploaded with a file.
        I have always corrected this kind of incident. Some of the things that don't look like a picture will be okay if you just change the powder once.
        For some, if it is not convenient to add a packet of pounder powder, throw it away and add a new packet.
        Now that I have the copy machine, I think it will be fine to put in another new bag of powder. Because it is convenient to add the entire drum unit from another machine.
        Can you tell me why some pounder powders are good to be added twice? I have a lot of losses.
        Please
        • Toxic
          • 698
          I dont understand what are you trying to say.
          Did you empty old developer from developing unit and put whole new packet of developer or you just add some new developer to existing old developer?
          Did you run tcr adjustment after developer replace?
          If you have complete imaging unit from another working 226 you can put in and check if that solve problem.
          Maybe it will be smartest idea to find some technician to solve that, it will save you money because 226 is basic model and problem finding is not complicated for moderately good technician.
