C1070 Press - Slow speed when printing double sided
  • phluid01
    • Jun 2015
    • 2
    Hello , we just purchased one C1070 press with RU516 + RU509 + FS532. No problems when printing one sided , but when printing 2 sided it's very very slow, like 1 page / 5 seconds. We've tried to set the output tray to main/sub , nothing changed. This is happening from all trays, including PF707 feeder.
    Anyone knows something about this ? Thank you !
  • tulintron
    • Jul 2014
    • 668
    Re: C1070 Press - Slow speed when printing double sided
    In paper tray settings you will find the process adjustment setting. There you will find settings for heating, dehumidification, load and speed. Run tests on all drawers before making changes to find out which tray has the problem and correct the settings in order to get your result.
      • 23010
      The factor that makes the most difference in speed is media type. The thicker the media, the slower the processing ... and that's entirely normal. =^..^=
      • phluid01
        • Jun 2015
        • 2
        That's the problem. I'm running on plain paper only, 80gsm. All trays are on default settings...
        • tulintron
          • Jul 2014
          • 668
          Print test pattern number 16 2>2 Double side and single side 1>1.
          In this way we eliminate the controller, printer drivers and Windows.
          If so the problem occurs, the error is in the printer.
          probable causes:
          Temperature
          paper configuration
          Humidity and temperature control
          firmware
          Good luck.
