KM C6000 C-0201 tray 1
  • Robin (ACS Collective)
    • Nov 2021
    • 21
    TLDR
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: KM C6000 C-0201 tray 1
    IIRC bit switch 18 0-8 should all be zeros 18-1 probably has a 1. (disable tray)?
    or just do a trouble reset.
      • Nov 2021
      • 21
      Thank you Synthohol.
      But switch 18 are all zeros.
      (Being desperate tried also switching to 1, rebooting, switching to 0 again and rebooting ... all giving the same error when inserting the tray.)
      And now to be honest I am clueless how to do a "trouble reset" and I don't find any intel about it for C6000 :-|
      • Synthohol
        • 5846
        boot holding panel reset if i remember, its been a while.
        also, thats the upper limit sensor code.
        either the actuator is out of place or the sensor is blocked with dust or paper fragment.
        it thinks the drawer is overfull and does not want to lift.
        could even be paper fragments in the connector.
        2.5.7 C-0201CodeC-0201ClassificationMain body: Paper feed tray abnormalityCauseThe upper limit sensor /1 (PS30) does not turn ON within a specified period of time after the paper lift motor /1 (M38) turns ON.Measures to take when alert occursThe main body stops immediately to turn OFF the power relay (RL1).Estimated abnormal parts• Printer control board (PRCB)• Paper lift motor /1 (M38)• Upper limit sensor /1 (PS30)• Pick-up solenoid /1 (SD7)CorrectionTurn OFF/ON the sub power switch (SW2) of the main body.Note• The message "Please call service" is displayed on the panel.Solution1. Check the paper loaded condition and the rear end restriction plate condition of the tray 1, and repair it if any abnormality.2. Check the connector connection and the wiring between PRCB and motor/sensor, and repair it if any abnormality.3. Check the I/O drive of the motor and the solenoid and the coupling of the gear, and repair/replace it if any abnormality. (Wiringdiagram: Main body (1/3):14-E, 15-M)4. Check I/O and the operation of the sensor, and repair/replace it if any abnormality. (Wiring diagram: Main body (1/3): 14-M)5. Replace PS30.6. Replace SD7.7. Replace M38 and PRCB at a time.Faulty part isolation DIPSWDIPSW18-0Control while detachedPaper feed in tray 1 is unavailable
          • Nov 2021
          • 21
          funny:
          • still clueless about trouble reset. Boot holding reset does nothing...
          • changed PS 37. Same error....
          • Had a deep view into the machine and recognized at the inner backside this plastic drive thingy for the up-down-wire is missing. Reassembled it and here we go - all good.
          i am so happy
