Konica Minolta C284
  • Kenny
    • Jun 2009
    • 533
    Konica Minolta C284
    Hi Guys,
    We have an issue with the magenta dev unit dropping dev onto the magenta drum charge unit causing pink strips on prints.
    Has anyone had this issue before,
    Its got the latest firmware on it, we have replaced the drum and dev as a set too but still getting the issue,
    All the consumable lives are over 50% and total count on copier is 300k
    • 14972
    Re: Konica Minolta C284
    Originally posted by Kenny
    Hi Guys,
    Did you use new OEM drum and dev unit?
    If you did, I would replace the high voltage board.
    • Kenny
      • Jun 2009
      • 533
      yes both OEM, will try hv board and update with you
      • tsbservice
        Field tech
        • 8053
        Clean toner duct and replace filters.
