Konica C368,cant print from windows 11 S Mode
  • acsolutions
    • Jun 2010
    • 519
    [Misc] Konica C368,cant print from windows 11 S Mode
    Hello, Cant find driver for C368, printing from windows 11 S mode. Any suggestions? Thanks
  • B0265
    • Jan 2007
    • 718
    Re: Konica C368,cant print from windows 11 S Mode
    I don't think you are allowed to install any downloaded software i S mode. You need to use a built-in driver.
    • davidmtupper
      • Jul 2021
      • 326
      This is a correct statement, however the customer can switch from S mode to full Windows for free, just change the license (google for details).
      • Synthohol
        Certified Konica Expert
        • 5823
        maybe best bet is save or print to pdf, put it on a flash drive and print direct from copier.
        • D Colour
          • Oct 2008
          • 213
          As other have mentioned Windows S mode only allows you to install apps from the MS store. There is one called "KONICA MINOLTA Print Experience" in the UK anyway.
          "This is a print settings application exclusively for Konica Minolta's MFP/Printer.You can configure detailed print settings when printing from Windows Store apps using V4 Universal Print Driver."
          Might be worth trying that, or converting to normal Windows.
          This is a print settings application exclusively for Konica Minolta's MFP/Printer. You can configure detailed print settings when printing from Windows Store apps using V4 Universal Print Driver.
          Everything that has a beginning, has an end.....
