Cyan and Magenta Developer Loss
  • CP-1015
    • Nov 2020
    • 323
    C-364e: Magenta Dev Loss, new developer, new drum and blade, TCR: -1 doesn't help, Air ducts clean as new one
    C-224 : Cyan Dev Loss, new developer, new drum and blade, TCR: -1 doesn't help
    Can someone confirm HV arcing on wire cover? Thanks advanced!
  • Gift
    • Mar 2011
    • 2459
    Re: Cyan and Magenta Developer Loss
    Since you seem to refurb the units wich always leaves room for funky issues: Did keep running the refurbed units just with life stop disabled or did you put a new chip in both DV and DR after refurbing?
    • Toxic
      • 698
      Had same issue with aftermarket drum on bw 224e.
      After replacing OEM drum problem solved.
      • CP-1015
        • Nov 2020
        • 323
        I've had reset drum and dev. C-364e: The drums and developers of all other colors have no problems during their lifetime.
        • Gift
          • Mar 2011
          • 2459
          OK, well you can either try and invest a set of new complete units and/or check the HV area + contact terminals/wiring/hv board for toner+dev contermination that might lead to bad voltages. Did you check the readings in service mode if anything looks off compared to the other colors?
          • CP-1015
            • Nov 2020
            • 323
            Thanks, I'll report!
            • CP-1015
              • Nov 2020
              • 323
              Vdc-M only 150Volt! Arcing on HV wire?
