Bizhub C3120i SMTP Problem
  • Imp
    • Sep 2023
    • 10
    Good Day
    I Wanted to install SMTP (smtp.gmail.com ) on Bizhub C3120i but results are only Fail.
    I checked every security option with 587 and 465 ports I also tried another smtp Office 365 but there was same sitation (FAIL) in this place we got another Bizhub (C227) and it works without any problem , any ideas what can be solution of this problem ? maybe someone had same problem with SMTP.
    • 30186
    Re: Bizhub C3120i SMTP Problem
    Gmail requires two factor auth ON then setup a apps password for the copier
    • Imp
      • Sep 2023
      • 10
      I already have google 2 factor authentication there
        • 30186
        Is it using the same account?
        check gateway and DNS settings
        • Mitch Barron
          • Mar 2013
          • 180
          BSM2, to my knowledge Gmail doesnt work any more for printers to be able to scan to email. that is why we been using office365
          are you been using gmail smtp to authenticate on your end?
          • KMFLT3CH
            • May 2017
            • 230
            Gmail still works just fine, I have numerous customers using their own private Gmail account to scan on their bizhubs. You need to have 2-factor authentication enabled and create an App Password under the Google account's security settings. The App Password must then be input in the MFP.
            KMBS USA made a handy dandy guide on how to do all this and configure the MFP: Scan to Gmail Using 2 Step Verification and App Password
            • copyrooks
              • Oct 2013
              • 209
              this model is a different animal from the other Konica models. There's a checkbox about Certificate verification. Uncheck it to see if it goes through.
              • Imp
                • Sep 2023
                • 10
                Are you using Gmail on Bizhub C3120i ?
                Im using Gmail on C227 without any problem , i have problem only with C3120i
                • Imp
                  • Sep 2023
                  • 10
                  yep im using same account DNS and Gateway works without any problem
                  • KMFLT3CH
                    • May 2017
                    • 230
                    Me personally? No. If you've done all the settings correctly than it sounds like it's a software limitation or missing security setting only on the re-badged printers? I have many different KM branded models old and new still using Gmail. I can't think of any re-badged printers in my area that have Gmail set up on it, IT dept. usually don't bother with the smaller machines and limit scanning to the larger MFPs.
                    • Imp
                      • Sep 2023
                      • 10
                      Update**
                      Problem Resolved
                      • KMFLT3CH
                        • May 2017
                        • 230
                        Update**
                        Problem Resolved
                        And what was the solution?
                        • Imp
                          • Sep 2023
                          • 10
                          Problem was in Gmail ( SMTP Settings )
                          • copier tech
                            • 8142
                            Can you be more specific ?
                            • zach93
                              • Apr 2024
                              • 2
                              What was the solution for this? Having the same issues and cannot figure it out.
