Bizhub C3350i
  • Costin1804
    • Apr 2023
    • 4
    Bizhub C3350i
    Hello,
    I have an issue with a Bizhub C3350i. The problem is that when scanning to email, out of 5 scans, I'm only receiving 2 or 3, not all 5.
    The fixes I've tried are:
    Changing the IP address.
    Changing the port in PP/Switch.
    Inserting the user/password account for the user ID.
    Trying another cable.
    Modifying the timeout from 60 seconds to 120 seconds.
    Is there anything else I can do to resolve this issue?
  • Kenny
    • Jun 2009
    • 538
    Re: Bizhub C3350i
    Originally posted by Costin1804
    Hello,
    have you made sure there is no IP conflict with your current IP address, had this before with our machine having the same IP as someones PC which would send 1 then error the rest.
    • strider5555
      • Jun 2008
      • 96
      Re: Bizhub C3350i
      You could check the default subject and text are not blank. Also try a different send from address/admin address.
      • tsbservice
        Field tech
        • 8076
        Re: Bizhub C3350i
        Error code please?
        • Gift
          • Mar 2011
          • 2459
          Re: Bizhub C3350i
          Error code please?
          makes sense
          In case it happens only with larger scan jobs there might be an issue with the resulting attachement size. Even in 2020 some providers allow very little attachement sizes up to ~20mb, especially the free ones.
          • suomi
            • Oct 2008
            • 155
            Re: Bizhub C3350i
            There have been cases where security printing is enabled and the network speed is 100, the scans did not go through.
            Speed changed 1gb.
            • mikeg
              • Oct 2023
              • 1
              Re: Bizhub C3350i
              Hello,
              Try changing your speed and duplex setting. Slow it down to 10 half
              • kingarthur
                • 1399
                Re: Bizhub C3350i
                Hello,
                There are 2 things you aren't telling us, firstly, are there any error codes, 2nd, you say that you aren't receiving every scan, if you aren't getting an error code, does it say "Job Complete" - in which the problem isn't with your device, it's a network/email issue
