i series reset CE password
  • jwai
    • May 2018
    • 517
    hello,
    i got one second hand 246i copier, found the CE password changed and cannot entet service mode.
    i checked admin setting don't have CE password setting, on got CE password request code, entered it but still displayed enter password screen.
    how to solve it?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4785
    Re: i series reset CE password
    Originally posted by jwai
    hello,
    how to solve it?
    Not sure what model a 246i is but have you tried all these common passwords:
    9272927292729272
    92729272
    9272
    12345678
    00000000
    • elmaligno
      Expert technician KM
      • Oct 2009
      • 302
      hello,
      how to solve it?
      Try with reset tool a789be. That will reset any CE password
      Field technician since 1994
      • tsbservice
        Field tech
        • 8064
        Try via Trouble reset.
        • jwai
          • May 2018
          • 517
          i tried it, after press trouble reset key, it need me enter CE password by using 10 key pad.
          • jwai
            • May 2018
            • 517
            how about the usage of this a789be.tar file?
            • elmaligno
              • Oct 2009
              • 302
              Its the same as when you update firmware. Follow instructions on service manual to know how update firmware, but use this file instead firmware files.
              • elmaligno
                • Oct 2009
                • 302
                • otphas
                  • Aug 2019
                  • 127
                  send me your email , will send you tar file .
                  • jwai
                    • May 2018
                    • 517
                    My email : km_jackywai@yahoo.com.hk
                    This .tar file will reset all CE password to default ( 9272 x 4 times )?
                    • jwai
                      • May 2018
                      • 517
                      9272927292729272
                      92729272
                      9272
                      12345678
                      00000000
                      I tried these passwords but no work, data initialized with a789be.tar and installed F/W again, same result.
                      Have method enter service mode directly? ( bypass CE password procedure or disable it on admin mode )
                      • strider5555
                        • Jun 2008
                        • 96
                        I am unfamiliar with a 246i, however on the c360i series and possibly others, there is a known issue with the CE password change and being unable to access service mode. First you need to do the CE password reset procedure as outlined in this PDF. CE Password Reset Procedure.pdf
                        The next step is to follow this procedure which involves a data clear. Cannot Access Service Mode After CE Password Reset.pdf
                        When you do the password reset procedure, it should take you straight into service mode, according to the first pdf. At that point you should be able to change/reset the CE password.
                        Make sure the codes you enter for the reset are spelled correctly/ proper characters. There are other people on this site that may be able to help you with the reset codes.
                        Hopefully this helps to resolve your issue.
                        • jwai
                          • May 2018
                          • 517
                          Thank you for your reply.
                          I only can login on normal user with email address and provided password, but login admin menu it need another user ID and password. How to register the administrator?
                          • blazebusiness
                            SanDiegoCopierRepair.com
                            • 1257
                            The machine was probably initially setup with bizhub secure and administrator lock to prevent anyb unauthorized changes and they then also changed the CE password also to prevent service mode access in the name of security.
                            To unlock admin you must enter enhanced security mode but until you solve the CE password issue and gain access to service mode, you will be unable to accomplish that administrator unlocking issue or anything else.
                            I'm surprised the backdoor access to service mode thru the trouble reset screen doesn't let you in.
                            As to those reset files, they seem to work ok on the 4 and 8 series but in my opinion do not always perform as is expected on the i series and sometimes cause more problems than they solve. Especially on the machines that were initially setup as bizhub secure.
                            • jwai
                              • May 2018
                              • 517
                              But I solve CE password issue, must enter admin mode of LMS website first.
                              I don't know the admin ID and password.
