c300i series drum edge damage
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    I look after multiple remote locations and minesites - this one is equatorial and has 90+% humidity every day of the year with constant temperature that never changes. It is not at all dirty all machines stay basically clean.
    I am changing 20+ drums every visit and there is no obvious cause. Print quality issue shows up before the coating failure but is not as obvious. Once the edge coating is perforated down to the aluminium core it is very obvious as pictured.
    Filthy minesites including another also an equatorial one with near identical weather conditions 6000km east of here has no such issues on same machines.
    Any ideas ?
    Prior E and 8 series here never had this issue at all.
  • Scope
    • Feb 2022
    • 16
    Re: c300i series drum edge damage
    This could help, we have had a few with this issue
    Drum Damage.pdf
    • Gift
      • Mar 2011
      • 2459
      [ATTACH]60006[/ATTACH]
      Thank's for asharing this doc - I've seen this issue every now and then, good to know the cause.
      • tsbservice
        Field tech
        • 8007
        Good thread. Thank you both for sharing.
        • tech51
          • 846
          The environment sensor can fail on the i series A3 range causing this type of damage,although it seems unlikely that multiple machines would fail simultaneously.
            • 23007
            This one isn't really lined up right for developer spacers. That's what I've seen cause the most damage.
            The only thing that really comes to mind is a customer I had many years ago that manufactured grindstones. On every surface in the office there was a fine layer of grit. That grit found it's way into every crevice of the machine, taking out drum after drum. There was no real solution to it, other than re-locating the machine to another building. =^..^=
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              This is exactly the issue, annoyingly, several machines have done it a second time and no mention is made of the lot number of when the pcr rubber composition changed. So we are just left to hope for the best at great expense.
              When first saw this issue about 12 months ago was told about this and was assured new drums would stop it happening, but here we are 😂
              • bowser
                • 25
                also note: theses drums are also squeaking bad you can lube them, take the 3 screws out and lube a small amount between drum and drive gear.
                • mascan42
                  • Oct 2008
                  • 484
                  Had the exact same problem with a customer that made floor tiles.
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    C750i drums are notorious for squeaking.
                    I've seen the black drum blade overheat and flips / stops cleaning properly on machines doing thousands of pages in a single run too. (c750i)
