Konica 2060L error
  • liondor1969
    • Jun 2016
    • 72
    Konica 2060L error
    hallo
    on my 2060L i have this error C2814...i tray too clean the sensor from inside left side wen is open ... i cleean all but after this wen the machine made autoajustment..wen made this..apeare this problem with blakc window call service C 2814
    please help my to finde the problem
  • Toxic
    • 697
    Re: Konica 2060L error
    Try to print test pattern from service mode and check black coverage .
    What is drum and developer life and machine total counter?
      • 23008
      I've seen this error when the black developer was detoned, and when the patch shutter was not opening completely. =^..^=
      • liondor1969
        • Jun 2016
        • 72
        ok,thanks..i must ceck contor..becouse i change this but forghet too reset contor
        • liondor1969
          • Jun 2016
          • 72
          i is that problem..developer unit loks ok for my ye i tray to reset contor..firsth
          • liondor1969
            • Jun 2016
            • 72
            Problem resove is..too change the cilinder,i put new on,naw all work ok..cilinder black cause this problem..
            Thanks for your help !
