C250i taking 6 mins to come to ready.
  • Scarekrow
    • Feb 2012
    • 83
    Hi,
    I have a Konica C250i thats taking 6 mins to come to ready, its using FW G00-09 verion 1 only done 2500 prints from new, is this normal on theres machines? I have done a logical format and waiting for suppliers to send me the latest FW I will update to, but appart from doing that has anyone else had this?
  • tsbservice
    Field tech
    • 8031
    Re: C250i taking 6 mins to come to ready.
    G00-23 was one of the earliest if not first mass firmware so updating is good point to start but not limited. They had many early faults cured later with firmware updates..
    • Synthohol
      Certified Konica Expert
      • 5868
      there are a bunch of reasons it can take so long to warm up.
      fuser/ toner/ IDC sensors, you name it.
      please be specific as possible like with screen messages.
      • Scarekrow
        • Feb 2012
        • 83
        IT shows the konica minolta logo and a space bar of aroud 25% if that helps?
        Under state confirm all toner levers are around 6% and IDC sensors are about equal
        • tsbservice
          Field tech
          • 8031
          There were a lot of failed SSDs in early machines, that was one of symptoms.
          • Konicatech
            • Feb 2016
            • 132
            I remember installing a lot of these machines when they were first released and thinking they took an age to boot up properly.
            Update the firmware and I think you will see some improvement - although as stated there were a lot of SSD failures, usually in my experience you won't get passed the boot screen if the SSD has failed - although I guess it could be a sign that the SSD is on its way out..
            Good starting point is updating the firmware.
            • Scarekrow
              • Feb 2012
              • 83
              I have updated the firmware, I found a usb in my tool kit with the Goo-J9 version so tried that and it warmed up a lot quicker so fingers crossed it will be ok,
              Has anyone got the movie data for the c250i?
              Thanks for all who replied.
              • allan
                RTFM!!
                • 5462
                Any scanner codes in the service logs? Had one do this and the scanner stopped the machine to boot completely. Funny thing is when its in that state it should still do print jobs...
                If so disable the scanner and DF for that matter under trouble isolation and it should boot quick and normal.
                Whatever
                • mascan42
                  • Oct 2008
                  • 485
                  Early firmware sometimes gets stuck at 25% just long enough that you think it's broken, and then moves on to 50%.
                  You need to update it, but make sure you go to function ver 2.0 first.
                  i-series GG1-73 Update Procedure.pdf
                  Also, don't forget in addition to movie data, it will also want PDF/A font uploaded.
                  • Scarekrow
                    • Feb 2012
                    • 83
                    [ATTACH]60202[/ATTACH]
                    i got this later, I have updated to Q8 firmware, I got the movie data and thats installed just need the pdf/a font,
