C224 FV 7 Suddenly unable to print and Access the Web interface
+ More Options
Posts
  • Synthohol
    Certified Konica Expert
    • 5850
    #16
    Re: C224 FV 7 Suddenly unable to print and Access the Web interface
    Christ on a cracker, thanks for verifying that.
    its obvious the wireless and wired networks are not bridged.
    is that your problem?
    • Kazzy
      • May 2023
      • 64
      #17
      They must have changed it last week. The wired equipment runs on a wifi server, totally different than the wireless devices. Or they changed something in that server and it doesn't allow bridging anymore for this particular mfp. If other machines work fine then this is definitely the problem. Not mine anymore, I informed them of the wireless kit which I believe should work with this model since it does work on the 224E version. They weren't interested in it. Looking at that server room, no wonder someone forgot to bridge a connection. I told them I ain't touching that. The grounding is screwed into a metal rod that sticks out through the floor, someone only has to trip and you have a 35cm rod stuck in your head or chest.
