C224e With Line on Scans and Copies
  • kenpio
    • Dec 2015
    • 202
    Good Morning,
    I have a customer that has a line going from front to back on their page. Not all the time. I changed drums and transfer belt. Now knowing that it does it on scans to. Example.jpg
    Any Ideas?
    KEN
  • Albonline
    • Sep 2008
    • 1153
    Re: C224e With Line on Scans and Copies
    Originally posted by kenpio
    Good Morning,
    I have a customer that has a line going from front to back on their page. Not all the time. I changed drums and transfer belt. Now knowing that it does it on scans to. [ATTACH=CONFIG]60236[/ATTACH]
    Any Ideas?
    KEN
    what about prints? are scans from flat on glass, or feeder?
    • kenpio
      • Dec 2015
      • 202
      Sorry, they are only from the feeder. They are not on prints. Copies and scans. Not off the glass.
      • Albonline
        • Sep 2008
        • 1153
        ccd most likely. have also seen the first mirror frame tip a bit when in the feeder position, causing the image to not hit the ccd correctly. try one on the glass.
        • Tech09
          • Apr 2020
          • 146
          Does the line occur in the same place every time it does show up? I'm guessing the paper is forming a small buckle right over the scan glass, is it hitting some burr or obstruction intermittently at that spacing? Given you have the edge deletion it's not a drum or transfer belt, it's being written that way.
          • kenpio
            • Dec 2015
            • 202
            It is not every scan that this happen. Some time the line is thinner than this one. I seems to happen in the morning.
