Konica C364e Tray1 jams
  • Apearsall94
    • Jul 2020
    • 11
    Hi Everyone.Just want to see if others have had this problem.Konica C364e,Only jams from Tray1- 9901 code.
    I know the cassette 1 is good and Paperfeed unit is good.Cleaned Reg roller and bearings.All other Trays feed fine except Tray1.
    When it does jam, tells me check paper size.Any help is appreciated.
  • D Colour
    • 213
    Re: Konica C364e Tray1 jams
    Is the paper size reading correctly on the display for what is actually in tray 1?
    Everything that has a beginning, has an end.....
    • SAR
      • Jul 2009
      • 199
      Check the reg sensor actuator. I had one where the spring on the actuator got weak and the actuator did not spring back fast enough causing similar issue to yours. Fixed it by putting 1 more wrap on the spring to make the actuator spring back faster.
      • Tech09
        • Apr 2020
        • 139
        Is it jamming on internal prints or copies or is it just while printing? I would reseat the memory card, run a full self diagnostic and flash firmware.
        • Apearsall94
          • Jul 2020
          • 11
          Yes.Only jams in tray.
          • tsbservice
            Field tech
            • 7926
            Try another registration roller clutch.
            • Apearsall94
              • Jul 2020
              • 11
              i can replace clutch, but wouldn't both trays jam if that's the issue?
              • tsbservice
                Field tech
                • 7926
                I had it on another model and it was also asking to check for tray paper size ended up being reg clutch.
                • 4Toon
                  • Mar 2023
                  • 107
                  Had this same issues but it was doing it on a c550i and from the bypass under 5k prints ended up being the main board might help might not just wanted to throw that out there even tho it was a diffrent model and tray.
