Hi all
I have a C450i at hand, the machine's memory card/SSD was wiped clean and won't boot up. I obtained firmware from a local contact, AA2J0Y0-F000-G00-Q8. I was told to put the entire folder "FW0020" under the root of the USB, which I did. However, after powering up the machine with "reset"-button pressed from the back of the display, the machine stays at boot screen and won't load firmware update routine.
What am I doing wrong?
Thanks in advance for your input!
