Konica Minolta bizhub 226 Error c2558
  • arhysmile75
    • Nov 2023
    • 4
    [Error Code] Konica Minolta bizhub 226 Error c2558
    I'm not an expert of KM ,and im sorry if my questions turns out to be stupid for you.
    i looked for an answer on the forum but didnt find anything.
    Previously i change OPC and developer powder on this machine and after a few days it returns to me with c2558 . The service manual said it was abnormal toner dinsity.
    in service menu Tn.D. was 145. then I checked the service manual and saw that the toner density should be 6% and i have 14%.
    After some thought i took out a tube of toner and started printing black sheets . After 20-25 sheets toner density was 63 , machine worked fine without stopping the sheet with error mesage,
    After this, I inserted the tube back and printed 10 sheets of text, the toner density rose to 130, and after a few more sheets the toner density became 145, and error c2558 came out again.
    i have a lot of questions. what and how should adjust the toner density. why this system does not work and where was my mistake. If someone know what to do , please tell me .Sorry for my english)
  • jwai
    • May 2018
    • 508
    Re: Konica Minolta bizhub 226 Error c2558
    After replaced developer powder, perform TCR adjustment with toner bottle removed.
    • arhysmile75
      • Nov 2023
      • 4
      )) Sorry for not writing all my steps in detail, but i read the service manual for replacing dev.powder. and did installation without the tube.
      • Toxic
        • 697
        Try OEM toner if you are not using it now.
        • arhysmile75
          • Nov 2023
          • 4
          I also thought about toner , but we have been using this toner for about 3 years at konica.
          Could it be that this toner does not work with the original developer?
          Отправлено с моего Mi 9T Pro через Tapatalk
          • Synthohol
            Certified Konica Expert
            • 5807
            i dont understand why you would just change just the developer when it not the right developer as the 226 sells as a whole unit for 60 dollars with the correct powder already in it.
            its a consumable, dont be so cheap next time
            • arhysmile75
              • Nov 2023
              • 4
              If i could i would do so, they are not fore sale in ukraine , and dev.powder cost me 60$
              • Toxic
                • 697
                @Synthohol
                What do you mean whole unit?
                As far i know there is developer powder bag and whole imaging unit assy for this machine and it is separate parts.
                Imaging unit comes without developer inside and drum so it is not really cheap to replace whole thing but it is good solution.
