Biz 8 series drums?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4679
    Biz 8 series drums?
    I've only rebuilt the 8 series drum units with new drum, cleaning blade, PCR, PCR cleaning roller & chip. Instead of rebuilding drums which cost almost as much as OEM black drum was thinking about just buying black drum units and converting to color.
    Can you convert a black drum to color by swapping blue end cap & chip? Or is there anything else that has to be done?
    Think I've seen this discussed here on forum.
    Thanks in advance
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    Re: Biz 8 series drums?
    Thanks in advance
    Blue piece no:
    1-A separator that it carries behind that blue piece (it is the one that marks the distance to the developing unit),
    2-The chip and
    3-A small casing that is attached to the middle of the drum with a very small screw, which is the one that prevents the drum k from entering in the CMY hole.
    If you put a color one next to a black one with my instructions, you will easily find those parts.
    Field technician since 1994
    • Don N.
      • Nov 2011
      • 409
      Originally posted by elmaligno
      Blue piece no:
      2-The chip and
      That's all we've been doing for years. OEM K to color as he says. Just use the DV spacers coming out of the old YMC drums i your new OEM K drums. There have been at least 2-3 versions. Some 1 piece. some 2 piece. No matter. Just use the ones that worked fine & don't intermingle old version with new version.
      So far, my inspection of i-series is same procedure, same chip to convert K to YMC. Only the the black plastic stopper that was screwed on an 8 series is now a formed tab that must be broken off.
