STRGB C250i.....
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    STRGB C250i.....
    Good morning to all colleagues.
    I would like to ask you if anyone has tried to put a STRGB memory (also called storage board or SSD) of computer, the normal one, the one sold in computer stores, instead of the STRGB of the Eagle/Sparrow that must be ordered from the manufacturer and are much more expensive.
    In both cases it would be necessary to install them and load the FW, but there is the doubt if the normal one would be recognized by the machine.
    This question is valid for the old NvMe STRGBs as well as for the more modern Sata M.2 ones.
    Thank you.
    Field technician since 1994
  • jwai
    • May 2018
    • 517
    Re: STRGB C250i.....
    i want to know too.
    • Max
      • Oct 2011
      • 569
      Originally posted by jwai
      i want to know too.
      I tried it, but it didn't work. Doesn't boot or takes the f/w
      • copytechtrouble
        • Nov 2020
        • 112
        Thank you.
        We've tried this and it doesn't work. the particular SSD used in the copiers is written into the firmware so the machine wont accept anything other than that make, model and brand (whatever it is)
        you can use one taken from another machine of the same model as long as its been formatted/wiped (and still working)
        • Copier repairman
          • Aug 2019
          • 86
          [QUOTE=elmaligno;2532550]모든 동료들에게 좋은 아침입니다.
          꼭 주문해야 하는 Eagle/Sparrow의 STRGB 대신에 컴퓨터 매장에서 판매되는 일반 컴퓨터의 STRGB 메모리(스토리지 보드 또는 SSD라고도 함)를 장착하려고 시도한 적이 있는지 묻고 싶습니다. 제조업체에서 제공하며 훨씬 더 비쌉니다.
          두 경우 모두 FW를 설치하고 로드해야 하지만 정상적인 FW를 시스템에서 인식할 수 있을지 의문입니다.
          이 질문은 기존 NvMe STRGB뿐만 아니라 최신 Sata M.2에도 유효합니다.
          감사합니다.[/인용문]
          SSDs for general computers could not be used.
          If there is a way, please share.
